prasa Posted April 4, 2011 Posted April 4, 2011 Hi Guys, In my honda ES08(manual), some times RPM was going down when AC on. when im trying to change gears(1st 2nd) RPM goes down to lowest level and generates less pulling power. I have done a Throttle body clean up and issue is still there. What would be the reason for this? U r feed back very much appreciated. Thnks Prasa.... Quote
Ripper Posted April 4, 2011 Posted April 4, 2011 AC idle up valve looks to be the culprit. any decent auto ac repair place should be able to fix this. Quote
prasa Posted April 4, 2011 Author Posted April 4, 2011 AC idle up valve looks to be the culprit. any decent auto ac repair place should be able to fix this. Thanks Machan.. U mean have to replace the idle up valve??? have u exp such an issue?? Quote
evergreen Posted April 4, 2011 Posted April 4, 2011 Thanks Machan.. U mean have to replace the idle up valve??? have u exp such an issue?? cleaning the idle up valve would sort out the problem. this is a common issue in ek range.not sure about the ES series. Quote
