Suzuki Alto Automatic Transmission
I have to a problem to change my car automatic transmission fluid.
My Car type is : Japanese Suzuki Alto
Transmission Type : Automatic
Problem : Change the transmission fluid.
Problem : There is no valve to remove the oil and only can be access through the oil measuring tube. My mechanical engineer said removing the sump is the only way to remove the oil. Is it correct or any other solution. Could you please help me.
2 answers to this question
