I have a Cefiro A33. There is a switch near the gear for AUTO - POWER . can someone pls explain the function of this. Which mode to be used during normal driving. Also please let me know about the overdrive function.
  • 1 month later...
Auto-power switch=
Most probably it should be the switch to power on/off the transmission leaver, so that it
might not be able to change accidently.
Overdrive Button=
It is used to off/on the the highest gear of the transmission.
Eg. If 4 gear automatic, if you off the OD, transmission will not get into the 4th gear.
Can be used in city driving condition where 4th gear seems not possible or when going downhill.
Reasons:
Will reduce the stress on transmission as no very large 3 to 4, 4 to 3 changes.
