venomafiax Posted June 22, 2011 Posted June 22, 2011 What is the recommended fuel(octane level) for a 250 motorcycle engine? Is it higher the Octane grade better the fuel economy? and engine durability? how does it work for cars? Thanks Quote
jdnet Posted June 22, 2011 Posted June 22, 2011 The more octane the better. Imaginary motorcycles are designed to handle fuel with a higher octane count. 1 Quote
The Don Posted June 22, 2011 Posted June 22, 2011 What is the recommended fuel(octane level) for a 250 motorcycle engine? Is it higher the Octane grade better the fuel economy? and engine durability? how does it work for cars? Thanks Use the manufacturer recommended octane grade (or the closest that is available in SL). Using high octane fuel by default does not always result in better anything ! Quote
Sifaan Posted June 22, 2011 Posted June 22, 2011 Using high octane fuel by default does not always result in better anything ! sorry to nitpick Don, but it does result in faster depletion of wallet contents. Quote
The Don Posted June 22, 2011 Posted June 22, 2011 sorry to nitpick Don, but it does result in faster depletion of wallet contents. Ha ha ha, whether that is "better" is debatable Quote
venomafiax Posted June 23, 2011 Author Posted June 23, 2011 Use the manufacturer recommended octane grade (or the closest that is available in SL). Using high octane fuel by default does not always result in better anything ! But the question is... is the Premium Petrol at the IOC filling station really 91 Octane? and what they say it has some additive which is a friction booster and bla bla... What octane is the Premium petrol ? Octane 90 with some friction Additive or Octane 91? and is it safe to use? Coz if its not same the Only Other Alternative would be the Octane 95 which is not what im looking for and Like Sifaan says Depletion of the wallet!! Quote
Sifaan Posted June 23, 2011 Posted June 23, 2011 But the question is... is the Premium Petrol at the IOC filling station really 91 Octane? and what they say it has some additive which is a friction booster and bla bla... What octane is the Premium petrol ? Octane 90 with some friction Additive or Octane 91? and is it safe to use? Coz if its not same the Only Other Alternative would be the Octane 95 which is not what im looking for and Like Sifaan says Depletion of the wallet!! i don't know what crap they add in their petrol but when I know they're selling snake oil (nitrogen for tyres) i'm disinclined to trust what they say about fuel additives. does it say somewhere (manual? internet?) that your bike needs 95? Quote
The Don Posted June 23, 2011 Posted June 23, 2011 (edited) But the question is... is the Premium Petrol at the IOC filling station really 91 Octane? and what they say it has some additive which is a friction booster and bla bla... What octane is the Premium petrol ? Octane 90 with some friction Additive or Octane 91? and is it safe to use? Coz if its not same the Only Other Alternative would be the Octane 95 which is not what im looking for and Like Sifaan says Depletion of the wallet!! Look Venonmafiax, The quality of Petrol in SL has been found to be variable. It is so variable to a point that D*MO used to advice Mercedes owners to use standard 90 octane petrol on their cars. Also if you search through the forum, you would know that fuel additives etc are things to be used sparingly and there are some who avoid it like the plague. Personally I would only add an additive for a very specific purpose and only as a short term measure (say to clean my injectors). This is because the long term effects of some of these additives are not always know and not always positive. Some are claimed to contribute to the chemical break down of oil causing sludge. Also a recent study in the UK concluded a lot of the additives manufacturers of petrol add to fuel in general don't deliver the results they claim consistently. To be fair to the manufacturers some of it is down to different engine designs as well. So in short use the grade of fuel you are advised to use and don't use additives unless for a very specific short term purpose. This is the general consensus of the forum. Edited June 23, 2011 by The Don Quote
venomafiax Posted June 24, 2011 Author Posted June 24, 2011 (edited) i don't know what crap they add in their petrol but when I know they're selling snake oil (nitrogen for tyres) i'm disinclined to trust what they say about fuel additives. does it say somewhere (manual? internet?) that your bike needs 95? compression ratio of 11.5:1 and i read it says recommended octane 91 - 93 Just not sure if the IOC's Premium is Safe coz a frnd of mine recently had to do a rebuild of his engine!! he was using the Premium!! all the time! Edited June 24, 2011 by venomafiax Quote
The Don Posted June 24, 2011 Posted June 24, 2011 compression ratio of 11.5:1 and i read it says recommended octane 91 - 93 Just not sure if the IOC's Premium is Safe coz a frnd of mine recently had to do a rebuild of his engine!! he was using the Premium!! all the time! Standard 90 octane available in SL is fine for your engine (if it really requires 95 it would say 95-98). I don't think quality of fuel will cause an early engine rebuild particularly over a short period of time. Quote
venomafiax Posted June 24, 2011 Author Posted June 24, 2011 Standard 90 octane available in SL is fine for your engine (if it really requires 95 it would say 95-98). I don't think quality of fuel will cause an early engine rebuild particularly over a short period of time. Yeh i guess ill stick to the 90... just got in with a topic on a Bike forum... guy says avoid the Friction booster stick to the 90!!! Quote
