Schiffer Posted July 1, 2011 Posted July 1, 2011 Hey guys, recently my headlight start acting wierd when i use the low beam.. the right side is low and the left is high and when i use the high beam, the left right side is high and the left is low,, and at all the times, the blue light on the dash is ON.. i showed it to a electrician and he said that the switch is broken, just want to confirm it before buying a new switch.. thnx Quote
Simplelife Posted July 1, 2011 Posted July 1, 2011 Hey guys, recently my headlight start acting wierd when i use the low beam.. the right side is low and the left is high and when i use the high beam, the left right side is high and the left is low,, and at all the times, the blue light on the dash is ON.. i showed it to a electrician and he said that the switch is broken, just want to confirm it before buying a new switch.. thnx I faced a same sort of problem with my Lancer sometime back, I mean when only the left head light was working plus had the blue light on the dash was on, the fix was pretty simple actually.. the wire connecting to the right head light bulb had a loose connection so the guy who repaired it fixed it properly and it was perfect after that.. didn’t have to change the switch in my case. Quote
jami Posted July 1, 2011 Posted July 1, 2011 Hey guys, recently my headlight start acting wierd when i use the low beam.. the right side is low and the left is high and when i use the high beam, the left right side is high and the left is low,, and at all the times, the blue light on the dash is ON.. i showed it to a electrician and he said that the switch is broken, just want to confirm it before buying a new switch.. thnx electrician wrong, dont buy a switch just check with the connections Quote
Schiffer Posted July 1, 2011 Author Posted July 1, 2011 thnx guys.. and yes i too thought so,, have to go and show my usual electrician and get a verdict from him Quote
Schiffer Posted July 1, 2011 Author Posted July 1, 2011 sounds like a bad ground on one light ano... ground?? Quote
nexus Posted July 1, 2011 Posted July 1, 2011 i have the same problem in my previous double cab some time a go and when we take it to a car electrician he said some one have change the wire connection in wrong order after he fix it in right way problem is solved. Quote
Schiffer Posted July 1, 2011 Author Posted July 1, 2011 i have the same problem in my previous double cab some time a go and when we take it to a car electrician he said some one have change the wire connection in wrong order after he fix it in right way problem is solved. the wiring of this car has been disrupted by the previous owner,, there are some door light issue's too, whenever i open the the door, the door light switch off, and close the door the door light switches on.. Quote
nexus Posted July 1, 2011 Posted July 1, 2011 the wiring of this car has been disrupted by the previous owner,, there are some door light issue's too, whenever i open the the door, the door light switch off, and close the door the door light switches on.. in that case i think it is best to check whole electric system of the car who knows what's that idiotic previous owner done to the car. Quote
Schiffer Posted July 1, 2011 Author Posted July 1, 2011 seriously mate, planing to go to my usual electrician, and mate, do you know any place where i can fix my power mirrors too? Quote
nexus Posted July 1, 2011 Posted July 1, 2011 seriously mate, planing to go to my usual electrician, and mate, do you know any place where i can fix my power mirrors too? you want to buy power mirrors and fix them to your car or you want to fix your existing power mirrors? in this case what is the problem may i ask. Quote
Schiffer Posted July 1, 2011 Author Posted July 1, 2011 you want to buy power mirrors and fix them to your car or you want to fix your existing power mirrors? in this case what is the problem may i ask. wanna fix my existing power mirrors, the left side power mirror goes down and right, but cant turn it up and left (._.) Quote
nexus Posted July 1, 2011 Posted July 1, 2011 (edited) wanna fix my existing power mirrors, the left side power mirror goes down and right, but cant turn it up and left (._.) ok you want to repair them in kandy? any ways i will send you a pm about details. Edited July 1, 2011 by nexus Quote
Schiffer Posted July 1, 2011 Author Posted July 1, 2011 yeap mate, im from kandy as well and thanx alot mate Quote
nexus Posted July 1, 2011 Posted July 1, 2011 yeap mate, im from kandy as well and thanx alot mate any time mate if you have any more questions feel free to ask. Quote
Schiffer Posted July 1, 2011 Author Posted July 1, 2011 any time mate if you have any more questions feel free to ask. lol defa i will mate. thnx Quote
