Cefiro Gearbox Problem
aaa-cef
Hi all, when i am speeding my Cefiro A33, sometimes at the speed of 70-80>kmph gear slips. It changes to the lower gear then suddenly to the correct one, while happening it, the engine RPM will go high (ex:4000 or so) then back to normal soon as it is back to the correct gear. This happened 2-3 times during the last month. Appreciate if someone can help me to identify the problem.
Cheers....
7 answers to this question
Cheers....
check for error codes first. if its nothing to do with the speed sensors and anything electronic then its the clutch packs slipping. there is a guy call chandana he is good try this number go there and show the car. 0773027118
Cheers....
if it's a sudden accelaration this is a normal thing done by the box to increase pickup
this is called a pin-down
Thank you v much mate. Appreciate your support......
