Rpm Idle
ashraf
  On 7/18/2011 at 7:47 AM, ashraf said:
what is the normal RPM on N & D positions (auto/1500 cc)?
and when we switch on the AC, the RPM should go higher or lower
what is idle RPM ................ :food-smiley-004:
Idle on N = 700
When D about 600
When AC on, again about 600. Means due to the load on engine, RPM goes down.
  On 7/18/2011 at 11:28 AM, Uditha88 said:
Idle on N = 700
When D about 600
Idle RPM depends on vehicle Make/Model and may be engine type as well. Further, When the A/C is switched on, RPM should rise, provided that the idle up mechanism works properly. With a working idle up system, engine will rev higher to compensate the additional load on the engine due to compressor + condensor fan/auxiliary fan and to provide effective cooling/gas recirculatioin of the A/C system. If the RPM goes down with the A/C on, that means a makabass has messed up with the idle up mechanism.
harshansenadhir is correct.. when AC is turned on the RPM should go up slightly.. anyway it may depend on the make and model. try to download the manual of your car from the website there you can find the exact idle RPM.. as i remember a toyota 110 idle should be 750. idle RPM is very important to maintain the necessary oil pressure at idle , + engine mount health + correct emission range etc etc.. :)
Cheer, :alc:
Archon
