Ruwanal Posted July 23, 2011 Posted July 23, 2011 Hi, I have a problem with my Hiace KDH200 sliding Door. It is very difficult to close the door. but when front doors or windows are open it can be close with out any difficulty. I have taken for many places, but still couldnt fix the problem. Any body could help in this? Thanks Quote
Abbas Posted July 25, 2011 Posted July 25, 2011 Hi ! It's actually a very simple thing! Near ur rear (decky) boot door u get two pressure releasing vents! When these vents get covered or stuck ur vehicle air inside has no place to go! That the reason when u leave ur shutter or front door open the rear door closes easily.u will need to find those vents located near the rear boot door ! It's normally located on the inside on the top of the rear boot door.check and see if the flap has got stuck or covered.u will need to take the side pannel of the rear to reach this ! So i advise u to get help of a person who has experience a bit.hope this helps. Quote
Ruwanal Posted July 25, 2011 Author Posted July 25, 2011 Hi ! It's actually a very simple thing! Near ur rear (decky) boot door u get two pressure releasing vents! When these vents get covered or stuck ur vehicle air inside has no place to go! That the reason when u leave ur shutter or front door open the rear door closes easily.u will need to find those vents located near the rear boot door ! It's normally located on the inside on the top of the rear boot door.check and see if the flap has got stuck or covered.u will need to take the side pannel of the rear to reach this ! So i advise u to get help of a person who has experience a bit.hope this helps. Many Thanks! Quote
