Helo
I have mazda axela 2004 and it has the radio with the freuency of FM90 and i need to enhace it to FM 108 . Please tel me whenther i can replace the setup with a another
Thx
7 answers to this question
There are very few options available in SL as the perfect fit for the factory HU cannot be easily found.
But you can take off the original HU very easily but then you'll need to find something like this which is custom built for M3: Eonon D5102
Or you can find a dash kit modifier + wire harness like this: Eonon A0508 OR get a local version fabricated and then fit a standard 2-din setup or DVD fitted in.
I've seen the Eonon models in SL once 2 years back but nothing recently.
You can try with usual AV guys to import such a thing and install or you can import by yourself (~ $420) although I do not know how much taxes+duty this would attract.
Edited by vishkid
you can use a frequency shifter to change the frequency band. Any A/V guy will do this.
Or go for a HU made for Mazda 3. There are few models made for Mazda 3.
Frequency modifiers are messed up dude, everything goes all wonky, I say change the HU.
Where hv u seen HU replacements for M3 (2004-2009) around Colombo? One of my colleagues is also interested but there's next to nothing as per him.
I can't recommend a place or brand. Because I haven't used them. But most of the leading car A/V shops have HUs for M3. Easiest way is just grab a Hit@d...
Yes, it's a mess. But it is cheaper... and good as a temporary solution... I mean till you get a good HU...
:) Apparently not - zilch in HitAd, ditto Pet#o, ditto Gilbert (although they promised to bring down one for 64k!!)
Edited by vishkid
