I just went through the procedures of this URL to find any electrical leaks because I found that when the jeep (4DR5 J44) is idle for few days the batteries are getting weak. So the result I got is 3.3 which would be a problem according to the above post. (I have mentioned the steps that the above post has said to find an electrical leak below).
I removed the fuses one by one to see what is the problem but even after removing the last fuse i got the reading as 3.3 Amps. It means (Lets hope) the problem is in between the battery and the fuse board. I am sure anyone of you have gone through this problem before or at least know something about it. So please kindly post your answer which I really thank you in advance.
STEPS
Step 1: Setting up the volt meter. Connect the test leads to the appropriate spots. Negative in the negative spot and positive to the 10A spot. Set the meter setting to 10A on the dial as well. I used the full amp setting for this test but you can use more accurate settings if you preffer. Your battery must also have a charge when performing this test. You can use the volt meter to test this by connecting the positive and negative leads to the positive and negative battery terminals respectively. The reading should be somewhere around 12.6 Volts if the battery is 100%.
Step 2: Disconnect the negative battery cable from the negative battery terminal. As per bluej511, this test may require that you connect the leads to the terminal and cable before disconnecting them (see step 3). This is because the draw might be coming from a relay that might close when the terminals are disconnected and the circuit is broken. This wasnt necessary in my case but your case may be different.
Step 3: Connect the negative lead to the negative battery terminal and the positive lead to the negative wire (ground wire) and check the reading. If there IS NOT an electrical leak, the reading should be around 0.01. Might be from 0.00 - 0.05 depending on the vehicle. You can always call the service department at your local dealership like I did to get the specification. This small current is to keep small things running such as ecu memory, stock alarm ext. The reading I got was anywhere from 0.15 - 0.21 so there was definitely a problem.
Step 4: Begin to pull fuses one at a time until the reading drops to where it should be. Keep in mind that there are fuses that must be screwed in that will channel all the electricity from the battery (100A and 40A in my case). Removing these will result in the reading dropping but these are not the source of your issue. It is a good idea to start with any fuses that would most likely be the cause of the problem. Aftermarket things such as decks or if you recently replaced your headlamps as examples
Officially joined the thel-hinganna normie horde with ....drumroll... a 2025 Vezel... I am eagerly anticipating joining the 'thel keeyak karanawada' debates at almsgivings.
Recently, got the opportunity to see and get inside of The one and only Japanese V12, Toyota Century(a.k.a Japanese Rolls Royce). Is it really upto Rolls Royce standards? Nope, I don't think so. Items like Switches and mirror housings are in plastic. But, we can be assured that the dashboard will not light up like Christmas and would run forever....
Nishan.dj
Hello friends,
STEPS
Edited by Nishan.dj4 answers to this question
