iPrabhath Posted October 12, 2011 Share Posted October 12, 2011 Hello friends, I recently bought a FB15 Super Saloon (1998 model) and its key has a remote door locking function on it, but not working at the moment. I checked the battery on the key and it has not been discharged. Can someone provide me a way to troubleshoot the remote locking function. Thank you. Quote Link to comment Share on other sites More sharing options...
Anjo Posted October 12, 2011 Share Posted October 12, 2011 On 10/12/2011 at 6:16 AM, iPrabhath said: Hello friends, I recently bought a FB15 Super Saloon (1998 model) and its key has a remote door locking function on it, but not working at the moment. I checked the battery on the key and it has not been discharged. Can someone provide me a way to troubleshoot the remote locking function. Thank you. Well if the central locking works fine when you insert the key in the lock, then probably either the transmitter (in the Key) or the receiver (hidden somewhere inside the dash or kick panels, usually on the passenger side on most Nissans) is malfunctioning. Try with your spare key. if not, download the service manual for your car and follow instructions on that to find, check and replace the controller responsible for the function. Quote Link to comment Share on other sites More sharing options...
The Don Posted October 12, 2011 Share Posted October 12, 2011 On 10/12/2011 at 6:16 AM, iPrabhath said: Hello friends, I recently bought a FB15 Super Saloon (1998 model) and its key has a remote door locking function on it, but not working at the moment. I checked the battery on the key and it has not been discharged. Can someone provide me a way to troubleshoot the remote locking function. Thank you. You can take it to a place like s u n lanka and they will trouble shoot it for you. Be mindful that they might try to sell you one of their own systems. But if you have an IR detector you can check if the key is emitting a signal when the button is pushed. Then you need to figure out where the receiver is and try to reprogram the key. If the receiver does not respond you might have to get the receiver replaced or repaired. Considering the cost of an after market system this might be more hassle than its worth. I know because I tried the same on my car already Quote Link to comment Share on other sites More sharing options...
Isuru Udana Posted October 12, 2011 Share Posted October 12, 2011 On 10/12/2011 at 2:10 PM, The Don said: You can take it to a place like s u n lanka and they will trouble shoot it for you. Be mindful that they might try to sell you one of their own systems. But if you have an IR detector you can check if the key is emitting a signal when the button is pushed. Then you need to figure out where the receiver is and try to reprogram the key. If the receiver does not respond you might have to get the receiver replaced or repaired. Considering the cost of an after market system this might be more hassle than its worth. I know because I tried the same on my car already These remotes are not using IR, so this method wont work. Quote Link to comment Share on other sites More sharing options...
Isuru Udana Posted October 12, 2011 Share Posted October 12, 2011 On 10/12/2011 at 6:16 AM, iPrabhath said: Hello friends, I recently bought a FB15 Super Saloon (1998 model) and its key has a remote door locking function on it, but not working at the moment. I checked the battery on the key and it has not been discharged. Can someone provide me a way to troubleshoot the remote locking function. Thank you. Fault can be on the following items Key (Transmitter) Smart Entrance Control Unit (Receiver) Multi-Remote Control Relay Fuses First check fuses, then Relay. Then check Smart Entrance Control Unit - This can be done using the method which is used to program the key. Quote Link to comment Share on other sites More sharing options...
iPrabhath Posted October 13, 2011 Author Share Posted October 13, 2011 Thanks all for the valuable replies. I checked the fuse box of my car and I couldn't find the relevant fuse and relay.But I notice that fuse called "anti theft" is missing (I suspect this is the relevant fuse).Then I placed the fuse of the horn to the anti theft fuse slot and tried the key. It didn't work for me. Isuru, can you please post the locations of the units you mentioned in the reply (Smart Entrance Control Unit (Receiver), Multi-Remote Control Relay ,Fuses). Quote Link to comment Share on other sites More sharing options...
tiv Posted October 15, 2011 Share Posted October 15, 2011 On 10/12/2011 at 6:16 AM, iPrabhath said: Hello friends, I recently bought a FB15 Super Saloon (1998 model) and its key has a remote door locking function on it, but not working at the moment. I checked the battery on the key and it has not been discharged. Can someone provide me a way to troubleshoot the remote locking function. Thank you. Is this a factory fitted unit or an aftermarket unit? Quote Link to comment Share on other sites More sharing options...
Isuru Udana Posted October 15, 2011 Share Posted October 15, 2011 On 10/13/2011 at 1:37 PM, iPrabhath said: Thanks all for the valuable replies. I checked the fuse box of my car and I couldn't find the relevant fuse and relay.But I notice that fuse called "anti theft" is missing (I suspect this is the relevant fuse).Then I placed the fuse of the horn to the anti theft fuse slot and tried the key. It didn't work for me. Isuru, can you please post the locations of the units you mentioned in the reply (Smart Entrance Control Unit (Receiver), Multi-Remote Control Relay ,Fuses). We can ignore the Multi-Remote Control Relay for now, as it is not present in some models. In one model, Smart Entrance Control Unit is placed behind the meter panel(hooked to the meter cluster). And in the other model unit is placed somewhere near to the AC Filter in the passenger side. But I think you don't have to locate the unit to check whether it is functioning. Go inside the car, lock all doors (using the driver side lock). Insert the key into the key cylinder and remove it from the cylinder six times or more within 10 seconds. Then door locks should unlock. If so, we can say that your Receiver is functioning. You may have to try several times as this has to be done in the correct speed. 1 Quote Link to comment Share on other sites More sharing options...
iPrabhath Posted October 31, 2011 Author Share Posted October 31, 2011 Thanks in advance for the advice Isuru. I tried the Smart Entrance Control Unit test you mentioned above. It works fine . (It worked in very first try) What Should I do as the next step? If my key is not working , is there a way I can get a new key for a reasonable price? Quote Link to comment Share on other sites More sharing options...
Isuru Udana Posted October 31, 2011 Share Posted October 31, 2011 I don't think you can get a brand new one. But Check with agents. Have a ride to Delkanda area and try to find a reconditioned one. If you are successful in finding one then you can take out the circuit of it and put it into your key and get it programmed. Quote Link to comment Share on other sites More sharing options...
iPrabhath Posted October 31, 2011 Author Share Posted October 31, 2011 Thanks for the reply. From where can I get the key programmed? Quote Link to comment Share on other sites More sharing options...
Sha7 Posted October 31, 2011 Share Posted October 31, 2011 On 10/31/2011 at 5:53 AM, iPrabhath said: Thanks in advance for the advice Isuru. I tried the Smart Entrance Control Unit test you mentioned above. It works fine . (It worked in very first try) What Should I do as the next step? If my key is not working , is there a way I can get a new key for a reasonable price? Why don't you fix a new system? with security! Quote Link to comment Share on other sites More sharing options...
iPrabhath Posted October 31, 2011 Author Share Posted October 31, 2011 On 10/31/2011 at 8:07 AM, Sha7 said: Why don't you fix a new system? with security! That's a good idea too. you may refer to the Chinese security systems available here, what I don't like to add my car at the moment. At first I'll try my best to find another key and get it programmed ,if the price is reasonable. I'll keep your suggestion as plan B. Thanks Friend. Quote Link to comment Share on other sites More sharing options...
Isuru Udana Posted October 31, 2011 Share Posted October 31, 2011 On 10/31/2011 at 7:54 AM, iPrabhath said: Thanks for the reply. From where can I get the key programmed? it's a DIY kind of a job.I was explaining you the initial steps of programming the key to check whether receiver is working.I couldn't remember exactly the rest few steps. But you may able to find that doing a search.If not, go for a mechanic whose having a good experience with this car. Quote Link to comment Share on other sites More sharing options...
iPrabhath Posted November 1, 2011 Author Share Posted November 1, 2011 Anyone who knows the steps in programming a new key for Nissan sunny fb15? Quote Link to comment Share on other sites More sharing options...
Isuru Udana Posted November 1, 2011 Share Posted November 1, 2011 (edited) On 11/1/2011 at 4:48 AM, iPrabhath said: Anyone who knows the steps in programming a new key for Nissan sunny fb15? Try and see whether this works. program_key_N16.pdfFetching info... Edited November 1, 2011 by Isuru Udana Quote Link to comment Share on other sites More sharing options...
iPrabhath Posted November 1, 2011 Author Share Posted November 1, 2011 On 11/1/2011 at 5:55 AM, Isuru Udana said: Try and see whether this works. I think the link is missing. Quote Link to comment Share on other sites More sharing options...
