Swift Beetle Indian Gear Change Problem!
i bought a suzuki swift zxi indian model beetle car 2 months ago.it is 2008 model and done only 33000kms but im facing two problems when im drvng the car. :( :(
1)its bit late to start da engine sometimes.bt if the engine is heat can start witout delay!
2)and frequently hard to change the gear lever to the first gear and reverse gear also!i mean gears are not changing smoothly
is these are because of indian model???
help mee please.
Thank you.
2 answers to this question
OK sounds like your car needs a bit of adjustment and tuning.
First issue is most probably related to the fuel injection system. Get the fuel system, throttle body, injectors cleaned up and hopefully that problem will go away.
The second issue is either a problem with the gear selector, but most probably is the clutch and/or the pressure plate. Have it checked and if necessary adjusted or replaced.
First check your cold starting system
What is your gear box oil? is it EP90??? please never put EP90 for synchromesh gear box. Remove your gear box oil and flush with diesel. Then put GL4 or Thuban (caltex= easy shift or manual trasmission oil) or SAE 80 oil
