Hi Guys,
i am planning on converting my KR42 to Diesel. (Automatic)
Which engine should i buy?
3C
3C-E
3C-T
3C-TE
i like the 3C-TE coz one my friends converted using it and the van behaves almost-like a the petrol.
also have a friend who converted with a 3C and its not as responsive as the 3C-TE. I live in kandy so
What do you guys think?
3c-te is the quietest, most refined and most economical of the lot. people don't usually touch this engine because its semi electronic and because of that there's a shortage availability and parts. so its difficult to find ultra low mileage engines. also most people will somewhat hesitate to buy a vehicle with this engine for obvious reasons. its a bit more complex a conversion too because you'll need the ecu, dashboard and engine harnesses and instrument panel for a successful conversion, and the full 3c-te exhaust to get the full performance. not to mention the scooped bonnet that usually goes for about 45k. because you are running a k engine at the moment you'll need a new gearbox and ideally you should get new diffs too. I found the entire kit once for 550k which included a myriad of parts including the bonnet (though i managed to buy one for 28k at another shop).
All in all an expensive and a difficult conversion if you don't get all the parts from one place in one go. but if i were you i'd do it anyway and use the vehicle for a several years.
anyhow if you want to play it safe you can always go for the 3c-t. you can find a nice clean low mileage engine with some effort and parts are readily available. compared to the 3c-te this one doesnt need upgrades that stretch into the cabin. and a good electrician can easily wire up the engine. it will still keep up with 3c-te cos its only 3 bhp and 10 Nm shorter. This conversion kit would retail at around 350k for a 2wd and close to 400k for a 4wd (with diffs and gearboxes)
don't forget the 3c-t radiator. you'll definitely need one for uphill driving. it will come bundled if you are buying a kit
