Engine Removeal Toyota Liteace Cr42 33C Engine
which is the easyist way to remove engine from vehiche , Bydroping through the bottom or raising through the top?
'Hoss',
I have removed few engines by raising the vehicle then lover down the engine to a wheel tray and pull the tray to do the repair.
Easy way is pull from top. but from down also you can. but it takes time because you have to remove front suspension set.
Nilantha, have you ever done it this way? I agree with the other forum members, the bonnet space is quite tight to pull the engine out without banging on something.....
The Don,
Perfectly correct,
For heavens sake dont mislead members please.
MINIACE
