Guys, I have slightly bent the left lower arm bracket and the bolt that goes through the lower arm bush. Due to that the castor of that wheel is off by 2 degrees and car is pulling to left.
So I need to get the bracket and the bolt. I went through all the shops in Delkanda but none has them. So could anybody tell a place where I could get them ?
Checked with agents too but no luck.
If I can't find a replacement, will it be ok to try to straighten it ? Do you know Any good place who can straighten it to the original status (close to nugegoda) ? It's really a small bracket but affects alignment so I need to get this one correctly done.
Thanks.
US had bulk 110 spares...Please check.
MINIACE
Thanks but could you elaborate a bit ? actually I don't know where's the US :( could you give me the location and the full name ? anyway if its in delkanda I must have visited but I'll check again
Edited by Amila G
I think the bracket will need to be straightened out, the lower arm you will find eventually and the bolt worst case scenario you can get a machine shop to make one for you I guess worst case scenario.
