Vibration In Prop Shaft
guys,
after a sound appearing in my prop shaft in between gear changes i showed it to my mechanic and he had welded it . however now the sound is gone but there is a vibration in the car when moving specially in the 2nd high end and low end of the 3rd gear. i have attached the pic of my car.my friend tells me that there are 2 types of prop shafts one which is sealed and made to last the life time of the car and the other one which is repairable.
i am not sure how to solve this issue .
  • Author
i cannot upload it says too big........that sucks......i have a very clear image...
What the mechanic does is they remove the worn bearings by removing the locks which keep those bearing in the correct position.
They fix the new bearings and weld them to keep in the position but it is very difficult to properly align them even very minor misalignment cause vibration at certain speeds/gears.
I had the same issue in my CR27 (lotto), repaired twise yet the vibration remain so I replace propeller shaft with a used one.
Edited by nano31
I don't think any part related to engine gearbox and whole drive train should weld under any circumstances, because it cannot absorb the vibration, proper mechanic will replace it as necessary in genuine standards.
  • Author
the car is a lancer station wagon 1979........and the prop shaft comes to the differential with a cross connected to it they call it the kurusuya...... that is the one that is welded.
Oh! in that case you have to replace it with proper universal joint. When the job done it should be millimeter straight so driver shaft doesn't move but rolls.. Other thing is when you weld the joint it makes huge heat so bearing may cease in that process.
Edited by Malaka2
  • Author
machang if you have an email i can send the image to you...i crawled under the car today and took it to post it to the forum. this will give u a clear picture.
No need to see Mr Rameez, I get the idea. You have to replace the Universal joint again, but keep it mind don't weld it. It has locks in each end, but in case you weld it.. You have to replace whole thing.
  • Author
so now that he has welded it that means i will have to go for a new one.... :speechless-smiley-004:
  • Author
when u say universal joint are u referring to the kurusaya
Yes I refer that, but now I think you have to replace whole drive shaft.
Edited by Malaka2
  • Author
malaka where is the bearing in the photo u have posted.....is it before the kurusuya
No.. No.. The universal joint (Kurusaya) contains 4 bearings (Bicycle Balls) you can see those in Universal joint.
Your joint isn't same as this but basic is this. Now you weld the four ends, it ruined the drive shaft measurement.
Edited by Malaka2
  • Author
so when i took my car to the mechanic at first may be the bearing were the problem and had he not welded it then i could have saved the problem
tip - resize the image to make it smaller say 800x600
May be the bearings worn out could be the problem in that stage. But if you drove neglecting the problem too long drive shaft holes expand by the joint. But I believe you might have a chance to save if proper mechanic consulted.
Edited by Malaka2
  • Author
tip - restize the image to make it smaller say 800x600
tried that and still it was big
  • Author
well i dont want to say this.......but the mechanic is considered a mini expert and he is highly recommened in the forum...... :speechless-smiley-004:
Ya, could be.. These days most mechanic tries to save time in easy weldings... In motor mechanics there's no welding involvement. Every part has to be dismantle to replace when worn out.
Edited by Malaka2
Malaka is correct here, when welded the mechanical properties get ruined. But in SL people do that.
  • Author
i wonder why did this chap then do it.......being such an expert in vehicles......
  • Author
just for the info...generally is the prop shaft standard for any vehicle
