May 30, 201214 yr The cost ( Genuine Gasket set it has some more rings and items mechanic told me to keep it for future rep cost 7900 head facing and .. 5500 valves grinding or something 4800 spark plug set 2000 sametime replace engine oil and filter 3500 piston heads cleaning 2000 finally totall cost is 30000 now seems ok but the sound is somewhat different and seems not steady mechanic told me it will ok after doing some milage but feel to do an engine tuneup does it necessary or will it ok pls tell me good place to do an engine tuneup andreasonnable price. thanks. This could be because the ECU has been reset and still coming to grips with the current state of the engine. I'd say run the car for a little while before you do anything else. The so called tune ups these days is limited to cleaning injectors, throttle body and sensor clean up and spark plug change which you have already done. The most affordable place is your current mechanic as people have just made an industry of these so called tune ups when its actually a diy job
May 30, 201214 yr Author thanks I'll drive some milage as already clean and adjust even spend more money .thanks Don
June 7, 201214 yr Author After doing this repaire i noticed there is a problem when i accelarate and rpm shows 3000 to 4000 but the speed seems 30kmph to 40kmph and feel some resistance to move and suddenly feel jump then ok but this was not happen before do this repair is this due to wrong fixing pls help me to sort this sometime very difficult to overtake . sorry i fogot to tell this is auto gear kia spectra car. Edited June 8, 201214 yr by hatharasinghe
June 9, 201214 yr Not an expert but smells like a transmission broblem, maybe due to an ECU reset in the process.
