Uditha88 Posted July 10, 2012 Share Posted July 10, 2012 > Current Tire size "195 65 R15" > Book says "175 R14" > A manual says 175/65R14 175/70R14 185/65R14 185/65R15 Whts wrong with my current tire size? Quote Link to comment Share on other sites More sharing options...
kush Posted July 10, 2012 Share Posted July 10, 2012 Manual will be for all the versions of your vehicle, check what is in the door post that should be the ideal size. Once you know what your original size is you could use the following link to get the new size for your larger rim. http://www.kouki.co.uk/utilities/visual-tyre-size-calculator If the size is not matched properly your speedo reading will be wrong and will also affect the gearing (acceleration/ economy) Quote Link to comment Share on other sites More sharing options...
kevin1462 Posted July 13, 2012 Share Posted July 13, 2012 If you want to use a bigger tyre and if you are cool with fuel fugures the speedo can be re calibrated. Quote Link to comment Share on other sites More sharing options...
