fizz Posted September 22, 2012 Posted September 22, 2012 Hello! Kindly note that I put ma car for a interior clean up and after i came home i locked the car and car use to react and close with the side mirrors since from the beginning the car mirrors use to react, but after I had a drive their was a noise coming from the both the side mirrors and it automatically started to open and close up on it's own and it stopped and it got closed. So i took the car to a well know mirror maker and told him he told me that both the motors had gone and I replaced both the motors and now when I switch the react bottom from inside the car it doesn't closes up. So I would like to ask you guys opinion on this matter since I think may b the fuses had gone or is their any other issues related to this. Thanks Quote
Ripper Posted September 22, 2012 Posted September 22, 2012 retract you mean anyways...chances are somebody would've forced retracted the mirrors and it went out of sync. most cars have a BCM controlling retracting mirrors... not sure during interior cleaning if some wiring in that unit got loose or something. I would take the car to ruwan (rexxton motors, darley road near the fire brigade) and get him to check it for you. Had a similar issue in my corolla sometime back and this chap sorted it out fast... very reasonable rates too Quote
VVTi Posted September 22, 2012 Posted September 22, 2012 Think he is beyond that.. .somoene just replaced his motors without doing some troubleshooting first... Quote
chan5 Posted September 22, 2012 Posted September 22, 2012 retract you mean anyways...chances are somebody would've forced retracted the mirrors and it went out of sync. most cars have a BCM controlling retracting mirrors... not sure during interior cleaning if some wiring in that unit got loose or something. I would take the car to ruwan (rexxton motors, darley road near the fire brigade) and get him to check it for you. Had a similar issue in my corolla sometime back and this chap sorted it out fast... very reasonable rates too good joint. I also went to the place recently , and they cured my dead retract mirrors. Now works fine. Both mirrors, repaired and one shutter also was locked and repaired that too. About 2hour job . 1800 or so as i remember. Quote
