kmcsb Posted September 26, 2012 Posted September 26, 2012 (edited) i've done my eco test yesterday and seen tht got high hc ppm @idle.. @idle -455 2500rpm-160 but i passed..but i need to refersh wht tht was...previous report (last year) it was 160both...why is tht..wht are the problems..and where it was.. i changed oil,change,spark plugs(oem ngk),change air flter(vic) too... smell some pertol @exhast silencer also.. car -eg8 singlecarb Edited September 26, 2012 by kmcsb Quote
The Don Posted September 26, 2012 Posted September 26, 2012 Your car is running a bit rich. A Carb tune up is probably the first thing I would try and perhaps resetting some of the jets. If that doesn't work perhaps a repair using a carburetor repair kit might be in order. Quote
kmcsb Posted September 26, 2012 Author Posted September 26, 2012 hmm...tht means using more fuel...???isint it..also its hard to start on morning also...but i did carb clean few months ago..beter to do repair first... what are the sugesstion guys..help me.. Quote
The Don Posted September 27, 2012 Posted September 27, 2012 hmm...tht means using more fuel...???isint it..also its hard to start on morning also...but i did carb clean few months ago..beter to do repair first... what are the sugesstion guys..help me.. You need to go to a competent mechanic, and there are a good couple you will get to know of if you follow autolanka. Now it is possible your car has been tuned up to inject more fuel and generate more power by a previous owner (by using oversize jets). A carb repair is a subtle job, often messed up by mechanics who don't know what they are doing. Since the entire system is mechanical everything is in a fine balance for optimum performance of the vehicle. Many years ago Macro autotech did a reasonable job with my carb but there have been some negative reports about them recently, so I can't really recommend somebody myself. I think komisiripala has a good mechanic and Zackie Ismail is always cited for work on Honda's. But I have not used either personally. Quote
sammycajer Posted September 30, 2012 Posted September 30, 2012 hmm...tht means using more fuel...???isint it..also its hard to start on morning also...but i did carb clean few months ago..beter to do repair first... what are the sugesstion guys..help me.. Contact Wasantha:- 773088257 (Garage is located near zoo).. he did my carb repair & he used to work in stafford for 11 years.. seems to be he is good.. Quote
