Can anybody give me a diagram of timing belt pattern it should place in the car- I have already added it but im not sure of that "bass" has put it correctly...google a lot to find for my car but could not find..so if anyone knows it please put it in here..many thanks :)
Not really something you can sort out looking at a diagram and I am not entirely sure what the problem is. If you are concerned take it to another mechanic and ask him to check if the timing belt is installed correctly. To be perfectly honest, if its not your car is not safe to drive.
eh? all variants of the Vitz SCP10 have timing chains, not belts. Are you sure your car is a Vitz?
If you mean the pattern of the serpentine accessory drive belt, you need to figure out what your engine is; if it's the 1 liter, then it's a 1SZ-FE, if it's the 1.3 then most probably 2NZ-FE, I have to see one with a 2SZ-FE.
Edited by terrabytetango
