wait.. you know you have to look through ebay and yet you're asking for help? basically you want someone else to go through the hassle of searching through pages and pages of search result for you eh?
I wish you the best in life!
seriously dude like watchman said. you want US to find a bloody reverse camera for YOUR car on ebay?
u cheepo axio drivers. a reverse camera is around 3000-4000/- at a shop and u want to find one for more cheaper or you don't know how to go to a shop and ask? -_-
<blockquote class='ipsBlockquote'data-author="Nalaka Premarathna" data-cid="232949" data-time="1361006106"><p>
Before asking I searched... searched... searched... couldn't fine compatible one with "axio" only compatible with corolla... not sure whether it would match</p></blockquote> You will never find a one with Axio compatible label cuz Axio is a JDM model. Also I think what you have to see is the compatibility with you head unit.(colour scheme PAL/ NTSC).
Well the best thing to do is to go to a place like sun lanka or Pet#o and try out their replacement cameras. The ones you have referred to on Ebay seem to be two wire units while this seems to have only one wire. If you can find a working unit that way you can always adapt it to work with the bracket you have.
Alternatively Delkanda might have the original replacement and you might be able to get it off the relevant part of the body its connected to.
Your Axio is a _Corolla_. And did you try drying out the camera? Also nearly every cam on ebay will work with your car, what you need to do is find one with a similar mounting hole pattern, and the color system i.e. NTSC or PAL. The two wire model uses the second wire to power the IR emitters, to enhance the camera's night vision. AFAIK this function is handled by the camera itself without needing any further interface to the head unit.
