  • 6 months later...
the lancer, i think you will have to fabricate. or look for a cusco strut on yahoo japan auctions. those aren't cheap. will be aorund $200. so, much cheaper to fabricate. drop a PM to member Kelum_wj. he made one for his maruti.
for the ES8, i highly recommend you consider a bar from ultra racing. you'll find them on facebook. or just look for a guy called Abbas J. he'll hook you up.
Komi,
Is there a front strut bar and rear sway bar combination? There were several articles but difficult to understand. If I go for both, do I have to create special changes to rear suspension?
Mmmmmm....... Waiting for fix struts and sway bar soon. Ultra racing is busy these days. They don't have fb15 parts either so they plan to fix compatible one.
Now planning to for a place at Mount as Komi suggested. They are going to make them.
Anything to consider prior to make them? What should be the material? (steel, aluminium, iron etc)
Mmmmmm....... Waiting for fix struts and sway bar soon. Ultra racing is busy these days. They don't have fb15 parts either so they plan to fix compatible one. Now planning to for a place at Mount as Komi suggested. They are going to make them. Anything to consider prior to make them? What should be the material? (steel, aluminium, iron etc)
they don't seem to have anything... :(
At Abba's place (UR) only N14,16 not even sentra b15 available. But he said to send photos to find a compatible
The place at Mount, Komi has spoken to them. They've said they will design them . sounds good but When you hear it, lot of questions come mind. Same to me.
