Suzuki Liana Check Engine Light Problem
TheFlyingFox
Hello All,
I have a 2002 Suzuki Liana 1.3L. Recently the check light came and i went and checked it at Auto Miraj and it showed an Oxygen Sensor fault. I replaced that with a probe i got from Panchikawatta for 6k. Ran for about 15 KMs and again the check light came . Disconnected the battery and ran and somehow it comes back. This time when they put the analyser it showed a P0134 code. Fuel to Air ratio problem.
What seems to be the problem?
Thanks in advance.
http://lmgtfy.com/?q=Suzuki+Liana+Fault+Code+Po134
Jokes aside, suzuki-forums seems to be a good place to start... it seems american centric though so you may have to find out what the Liana or its closest equivalent was called in the US
http://www.suzuki-forums.com/suzuki-forenza-reno-forum/33201-fault-code-p0134.html
http://www.suzuki-forums.com/suzuki-sidekick-escudo-vitara-geo-tracker/22806-new-code-p0134.html
  On 8/10/2013 at 4:26 AM, TheFlyingFox said:
Thanks Supra but i have seached over the internet and couldnt find a solution. It runs normal but i cant stand the check light. This has the same engine as the Suzuki Swift which came in that time.
The second two links posted have discussions on the exact error code... There were one or two different areas to check, have you tried them?
