September 30, 201313 yr Hi All,I need help on good place to repair my broken tire wheel screw. While I tightening the tire nut on rear wheel I broke the screw there. See the pics to understand what I meant. Please let me know a place to get this repaired. Currently I m running out of 3 nuts in rear wheel. Thanks all.. Edited September 30, 201313 yr by Aravinda_2011
September 30, 201313 yr Hi All,I need help on good place to repair my broken tire wheel screw. While I tightening the tire nut on rear wheel I broke the screw there. See the pics to understand what I meant. Please let me know a place to get this repaired. Currently I m running out of 3 nuts in rear wheel. Thanks all.. Ami*a Tyre, Hill Street
September 30, 201313 yr ^^ what he said. Any lathe or tyre shop can do this for you. I broke mine sometime ago. The take a wedge shaped piece of metal, and force screw it into place on the hub. Simple really
September 30, 201313 yr Author Thanks for the responses.... any good place near Dematagoda, Borella or Maradana area? I am going to check in Darley Road too...But recommendation would help before I caught up with some other...
September 30, 201313 yr Try U&H Tyre service on Malay Street Slave Island, they usually have the wheel studs.
October 1, 201313 yr Author Thanks I went to U&H near Slave island station and got it fixed. Its very simple as said and not more than 15mts. I took more than that to brake it :-) thanks all again for support and guidance to pick it right.
October 2, 201313 yr OP now that you got it fixed would you be kind enough to tell us how you broke a wheel stud while tightening. Unless the stud had previously been put under undue stress, it is very unlikely for an average person (80kg) to brake one using a standard wheel brace.
