November 23, 201313 yr Dear Frinds, i just bought Mazda 323 (BJ6), Milage about 157K. i'm living in Ragama and i'm new to vehical ownershipi'm new to vehical ownership need advice on serviceaintance, what are the thing i should check, what are thing i sould change in my 1st Service. Good place to do maintance (service & repaire) for above mazda any special advice
November 24, 201313 yr if you have the previous maintenance records(genuine), things should be done depends on that. if you don't, then assumption should be biased towards the worst case (Ex: if MT->then change Transmission oil, AT->, then ATF).
November 26, 201313 yr Author Hi MV-5, thank you very muck. my one is auto, it looks like well maintain but do not have any recrds. i i hope that some text are missing is you post. friens please advice me on maintanace
November 26, 201313 yr Hi MV-5, thank you very muck.my one is auto, it looks like well maintain but do not have any recrds. i i hope that some text are missing is you post. friens please advice me on maintanace If there aren't any records then its best to change everything in one go so you can start fresh. Change engine oil, oil filter, air filter, fuel filter, check your spark plugs and change them if necessary (also check condition of plug wires). Change the Gearbox oil as well (ATF fluid). Check brake pads, discs and make sure they are in good shape. And finally check all the belts and hoses and make sure they are in good shape/replace those that are not. The oil and filter change can be done by any decent service station. For a mechanical checkup you should try Mazna Motors in pepiliyana, they know their mazdas inside out.
November 27, 201313 yr Author Thanks Supra_natural do any one recomond place near Wattala, kadana, Ja ele, kadawatha, peliyagoda, kelaniya, kiribathgoda, area...
