sira Posted March 23, 2014 Share Posted March 23, 2014 Hi, My EK3 AC compressor was replaced with little bit a bigger on by some body. anyway now that compressor also faulty. looking for a proper compressor. how much will be recon proper compressor? and where can I get it sira Quote Link to comment Share on other sites More sharing options...
Ek3 Ferio Posted March 31, 2014 Share Posted March 31, 2014 It would be around 10k, some ac joints supply it with a warranty too. I had to replace 3 compressors with in 1 year. But every time I had only to pay the service cost only. The place is near Battaramulla Koswatta. Quote Link to comment Share on other sites More sharing options...
Strikeee Posted March 31, 2014 Share Posted March 31, 2014 I have done a full A/C service and some repairs near jubilee post, nugegoda. It cost me 6500 for service + for treat the gas leak it cost me 3000 Quote Link to comment Share on other sites More sharing options...
jaga Posted April 1, 2014 Share Posted April 1, 2014 There is a good place at pattiya junction just before the over head bridge name AIR FROST. They are the people Who did all Honda A/C works before the agent got the facility in 90's. Abouit 10 yuears ago , my ek3 A/C condeser was changed to a bigger one and did complete overhaul and worked fine till i sold the car after 3 years.They have spares as well. Quote Link to comment Share on other sites More sharing options...
Strikeee Posted April 22, 2014 Share Posted April 22, 2014 Any idea how to repair a damaged temperature control unit(not the electronic one) of an EK3 or any place where you can get a replacement??? Tried several auto A/C spots, but none gave me a satisfactory answer Quote Link to comment Share on other sites More sharing options...
The Don Posted April 22, 2014 Share Posted April 22, 2014 On 4/22/2014 at 1:10 PM, Strikeee said: Any idea how to repair a damaged temperature control unit(not the electronic one) of an EK3 or any place where you can get a replacement???Tried several auto A/C spots, but none gave me a satisfactory answer Temperature control unit (not the electronic one), I'm not sure I know which component you are referring to. There is usually a thermostat close to the evaporator, and then there is an electronic unit that controls the temperature. Are you referring to the switches in the dashboard that allow you to move it from cold to warm? Quote Link to comment Share on other sites More sharing options...
Strikeee Posted April 22, 2014 Share Posted April 22, 2014 not, this is not an electronic one, Its a unit which has a railings and there is a needle(or a connector) which can be moved along the railings where the switch's(in the dashboard that allow you to move it from cold to warm) cable connects. ( i couldn't remove it or take a good look at it, because its there right under the center console of the dashboard.) Quote Link to comment Share on other sites More sharing options...
The Don Posted April 22, 2014 Share Posted April 22, 2014 On 4/22/2014 at 1:34 PM, Strikeee said: not, this is not an electronic one,Its a unit which has a railings and there is a needle(or a connector) which can be moved along the railings where the switch's(in the dashboard that allow you to move it from cold to warm) cable connects. ( i couldn't remove it or take a good look at it, because its there right under the center console of the dashboard.) Ok, sounds like you need the unit that the cable connects to (not the dashboard lever)? You should first check if it can be repaired. Most of these things are repairable. Else you will need to find a used dashboard from a part shop and take that bit out. Either way, dismantle and inspect first! Quote Link to comment Share on other sites More sharing options...
Chanaka Gunawardena Posted May 13, 2014 Share Posted May 13, 2014 Bought a recon compressor for my ek3 today from a place called Sasmitha compressor house in Navinna. It cost me 11,500/= Quote Link to comment Share on other sites More sharing options...
sira Posted May 14, 2014 Author Share Posted May 14, 2014 Hi Thank you guys for the valuable reply. I managed to fix this issue. One of my office friend’s cousin fixed this with no cost. the compressor - sandan was ok and only filled the gas. now it is working well. Found few things. The gas cost is 1100. And they charge 5000 for the service. This is not fair. What AC shops do is remove all the items and check the leaks. If there is an issue with condenser,...etc. you have to pay for that. So looks their labour charges are high, sira Quote Link to comment Share on other sites More sharing options...
macroxx Posted May 27, 2014 Share Posted May 27, 2014 If you replace the compressor, it's better to replace the condenser too if it is old. Otherwise the metal particles inside the condenser condenser will damage the compressor. Just a word Quote Link to comment Share on other sites More sharing options...
