September 4, 201412 yr Awesomeness... Narrowed down the areas that i need to check Thanks a lot Don! Does the pump go hard after pumping a few times? If it doesn't it can also be the hand pump. But usually this will result in being hard to start in the morning as well. Air can get into the line when the filter is not correctly set on its holder. Also remember the filter seals are for single use. If you take the filter off for any reason, you have to replace the filter. Else air can get into the fuel lines and cause starting issues.
September 4, 201412 yr Author yep, the pump becomes hard after several pumps. And even after i replaced the diesel filter, The issue still exists :S
September 4, 201412 yr yep, the pump becomes hard after several pumps. And even after i replaced the diesel filter, The issue still exists :S Then the likely candidate is the pump. Get it serviced and test after. Where the rubber lines connect to the copper lines, make sure you have adjustable clamps and they are tight, and the pipes do not move around.
September 4, 201412 yr Author Then the likely candidate is the pump. Get it serviced and test after.Where the rubber lines connect to the copper lines, make sure you have adjustable clamps and they are tight, and the pipes do not move around. yep, Gonna service the pump ASAP. Ill keep you guys posted
September 7, 201412 yr Author Solution Hi folks, I took it to the electrician today because i wasn't sure if its the pump because there's no miss or anything, he pointed out that the fuel cut off switch in the pump is faulty, so i got it replaced and all is well now
