I have purchased a second hand Toyota vitz (YOM-2007) recently. Like two three weeks back, the following problem occurred in the HID lights which installed as Low beam (only left):
1. When i switch on the low beam the bulb on with yellowand held like 2 mins and auto off. Again turned off and on the low beam via the switch, the result same.
2. So i replace the bulb of left side light and test the same, then bulb on with white and held for like 20 or 30 min and again auto off. (time vary)
This was the factory installed HID kit and i cannot understand where the problem really is,
Bulb,HID system, fuse, switch , etc. i thought of going for an electrician.
Officially joined the thel-hinganna normie horde with ....drumroll... a 2025 Vezel... I am eagerly anticipating joining the 'thel keeyak karanawada' debates at almsgivings.
Recently, got the opportunity to see and get inside of The one and only Japanese V12, Toyota Century(a.k.a Japanese Rolls Royce). Is it really upto Rolls Royce standards? Nope, I don't think so. Items like Switches and mirror housings are in plastic. But, we can be assured that the dashboard will not light up like Christmas and would run forever....
thusira
1. When i switch on the low beam the bulb on with yellow and held like 2 mins and auto off. Again turned off and on the low beam via the switch, the result same.
please help me some idea before i make that move.
Thank you in advance.
Edited by thusira5 answers to this question
