Problem With Windscreen Sprinkler - Honda Fit
I have a Problem with windscreen sprinkler - Honda FIT,
When i try to spray water to the wind screen the water drains out through the front rain water drain,
I guess it is loose connection, how difficult job it is to fix it ? and any idea why or how it can happen.
3 answers to this question
Loose connection is unlikely unless someone meddled with the tubing. Most likely cause IMO is a rodent attack. Rats are very fond of the tubing. In fact it happened to me once. If so depending on the extent of the damage you may have to either replace the tubing or cut the affected portion and reconnect with a tubing connector. You may have to partially remove the bumper to gain access to the tubing. For some it is a DIY job. But that depends on your skills.
Edited by Rumesh88
