December 29, 201411 yr Hi Guys, Need to know a good place to repair car roller window(Manual). Problem : Even the window crank turns, window does not roll up or down. Solution : not sure if this is DIY as we have to do it carefully without scratching the door panel etc.. Car : Suzuki Alto *Sorry if this is a re-post. Thanks in Advance.
December 29, 201411 yr Sounds like either the mechanism itself is broken or the glass has detached from the winder mechanism. Both not too difficult to fix. Take it to a place like LP Gunaratne in Darley road or your local window winder repair shop. The one I used to go to was in Delkanda junction.
December 29, 201411 yr Author Thanks, Delkanda is closer to me. Can you direct me to the place? Place u referred is at Highlevel road?
December 29, 201411 yr Well I do not know if it still exists but when you are travelling from Gansaba junction to Delkanda it was on your left hand side after the Majorie De Alwis International School
December 31, 201411 yr Author Ok Thanks. I was managed to fix it to a Tinkering guy nearby to Kottawa. Had to buy a new Window Winder for Alto. Cost me about 1700 LKR.
