January 6, 20197 yr Thanks for these step by step instructions. However , digging a little deep on this, I just found out that img file is actually an garmin compatible OSM (OpenStreetMap) , not actual garmin maps for Sri lanka. Actually you can download latest 2018 September OSM maps for Sri Lankan region from their site for free. And I also saw there's actual garmin 2018 maps for Sri Lanka for sale online for $19 and $29. If I purchase this will it be compatible with Honda indash system? Or does OSM have more routing data for Sri Lanka than Garmin?How do you know they are actually original Garmin maps?Sent from my AGS-L09 using AutoLanka.com mobile app powered by Tapatalk
March 9, 20197 yr thanks for the all who help in this forum ,i have succesfully done the srilankan update for honda crv 2018 aussi model steps 1. update the prevailin aussi maps as describe by the https://honda.garmin.com/honda/site/generalInstructions follow the instruction and see the video as well https://static.garmincdn.com/autoOem/honda/docs/en.pdf https://vimeo.com/176223246/324d0e0f5a after that install garmin express software in to your pc as in this pdf instruction https://static.garmincdn.com/autoOem/honda/docs/en.pdf then after aussi update complited come to your pc and go to this site and downlord the srilankan map as a img file http://garmin.openstreetmap.nl/ (it save as (gmapsupp.img) it is about 58 mg } select Mapnik Country as Srilanka in the filling then replace the same file in the usb which is a 42 mb file now again go to the vehicle and do the update process after starting the vehicle now you are done
June 22, 20197 yr when map update is downloaded to usb pen drive from garmin express, it has two .img files (gmapsup1 & gmapsupp). So replacing gmapsupp.img with sri lanka map will do the trick or do I need delete the other .img file ?
June 25, 20197 yr replaced only the gmapsupp.img file with downloaded SL map. everything work fine. thanks @WIKUM100
September 19, 20215 yr Anyone has the latest downloaded map from http://garmin.openstreetmap.nl/ Now there is no download option. I couldnt find a way to download the map. How about Mapmania.info website to download the map
September 19, 20215 yr Members, I don't think that you need a map on smart phones. I travel out of Colombo then I use the map on the phone that gives all I need. Sylvester Wijesinghe Sylvi.
July 11, 20233 yr hello, to use maps on the smart phone, you must have a data card for internet connection - how much data I will need in 30 days travel? which provider do you recommend when I want to travel around Sri Lanka? I will get a prepaid SIM card at the airport? Thank you,
August 30, 20242 yr Guys, I have an audi a5 b9 2019 with a virtual cockpit (VC). Is it possible to get Sri Lankan maps on the VC? Please help
