Honda Es8 Steering Rack Noise
My 1st post in AL :)
I have a honda civic es8 2002 model with electronic power steering and it gives taka taka noise which is really unpleasant
According to AL forum and from what I heard, I need to replace a bush(with teflon or nylon, and i don't know what is that bust is about).
I called stford and they told, replacing only the bush will not do the work and need some other parts also to be replaced , cost is about 25k with no warranty
Called another place in Maharagama (advertisement from hitad) they also told me the same story, bush+shaft repairing should be done.cost is 15k with 1 yr warranty
So I want to know past experience from the people who has done eps repairing and a good place where it can be done properly??
Edited by xxx-civic es8
worn out stabalizer link bar bushes(Google it) gives the same taka taka noise,It's a very cheap replacement unless you want to change the both links+bushes.You can simply get away replacing the 4 bushes only.But the garages may be getting an idea that you have a play in the rack center mechanism.First Just goto a simple garage and tell a guy to check if there's any play in the link bars or rack ends,simple hand shifting would give the noise.
