link to test
Cut n paste your true results !
Here are my results below.. this is ADSL
Speed
62.2 kilobits per second
Communications 62.2 kilobits per second
Storage 7.6 kilobytes per second
1MB file download 2.2 minutes
Subjective rating Slow
is it give true results
cable
Communications - 651.9 kilobits per second
Storage - 79.6 kilobytes per second
1MB file download - 12.9 seconds
Subjective rating - Not bad
Ethernet
Speed
1.5 megabits per second
Communications: 1.5 megabits per second
Storage: 186.5 kilobytes per second
1MB file download: 5.5 seconds
Subjective rating: Great
:lol:
ADSL 512kbps
Speed
61.4 kilobits per second
Communications 61.4 kilobits per second
Storage 7.5 kilobytes per second
1MB file download 2.3 minutes
Info
Date & time Thursday, February 2, 3:37AM*
Test type IDT4 Free
Connection type ADSL
Region Asia
Data size 1024KB
IP address
Provider
* EST (-0500)
SLT ADSL SUCKS
Hi Guys,
I have SLT ADSL 512kb and this is my results.
( I recently got this connection, I've heard the new SLT ADSL is faster than the old connections. don't know whether it's true)
112.4 kilobits per second
Communications 112.4 kilobits per second
Storage 13.7 kilobytes per second
1MB file download 1.2 minutes
Subjective rating Mediocre
Explain results
Info
Date & time Thursday, February 2, 5:44AM*
Test type IDT4 Free
Region Asia
Data size 1024KB
Regards,
Bharath
Here's mine,
ADSL
Communications 94.9 kilobits per second
Storage 11.6 kilobytes per second
1MB file download 1.5 minutes
Speed 103.1 kilobits per second
Communications 103.1 kilobits per second
Storage 12.6 kilobytes per second
1MB file download 1.4 minutes
Info
Date & time Thursday, February 2, 6:54AM*
Test type IDT4 Free
Region Asia
Data size 1024KB
IP address 222.165.174.181
115 kilobits per second
Communications 115 kilobits per second
Storage 14 kilobytes per second
Explain results
Info
Date & time Thursday, February 2, 7:33AM*
Test type IDT4 Free
Region Asia
Data size 1024KB
Mediocre. Yup, that describes SLT in a word. LOL
  fuzzo said:
link to test
Speed
Your results seem a bit lower than they should be? Are you on a shared network?
Im curious about ADSL speeds in the various regions in Colombo. I hear that people get different speeds in Kollupitiya, vs Nawala... and so on
Speed
93.3 kilobits per second
Communications 93.3 kilobits per second
Storage 11.4 kilobytes per second
Explain results
Info
Date & time Thursday, February 2, 9:03AM*
Test type IDT4 Free
Region not listed
Data size 1024KB
Speed
336.9 kilobits per second
Communications 336.9 kilobits per second
Storage 41.1 kilobytes per second
1MB file download 24.9 seconds
Subjective rating Not bad
Explain results
Info
Date & time Thursday, February 2, 9:47AM*
Test type IDT4 Free
Region Asia
Data size 1024KB
IP address
Provider
* EST (-0500)
Its not really the regions. ADSL speed can depend on the distance from the base station. If ur really close to the base station (or exchange), u get the closest to the advertised speed. The more wire from ur house to the base station, the lower the speed. I think it's to do with signal quality. That info should be on the web.
1.1 megabits per second
Communications 1.1 megabits per second
Storage 134.7 kilobytes per second
1MB file download 7.6 seconds
Subjective rating Good
Explain results
Info
Date & time Thursday, February 2, 11:20AM*
Test type IDT4 Free
Connection type SDSL
Region United Kingdom
Data size 1024KB
:lol:
hey guys...
i go online ona LankaBELL CDMA... it says the connection speed is 230.4Kbps....
but when i run the test i get this message..
i ran it a couple of time... same outcome..
The speed result was too high or too low
The speed test will not accept results that are negative or too high for the indicated connection type. This test was not counted.
Possible causes
* Using "back" from the results page
* Using a favorite link or direct URL entry to the results page
* Incorrect connection type selected
* This test does not support connections above 8mbit/s
* Network error
Solutions
* Start tests from the test start page
* Select the correct connection type
* Make sure you meet the minimum requirements to use this test
we have ADSL at office and at times it is hella slow. you speed also depends on how many other connections there are. if ADSL is new to the area, then you connection willb e very good. the connections are all shared, so if you have more users, dialup will be faster :lol:
Im using 2Mb ADSL Line Over a Network System ( Wireless + Rj45 Wired ) so i tested all of my computers in the network using the speed tester, but i got various results
( Wireless through a Router --> Server ) ( Network Speed 108MBPS 2.4 GHZ 802.11 )
Communications 152.1 kilobits per second
Storage 18.6 kilobytes per second
1MB file download 55.2 seconds
Then i tested one of my cliant pc ( RJ45 through a Router --> Hub --> Cliant ) ( Network speed 100MBPS )
Communications 100.2 kilobits per second
Storage 12.2 kilobytes per second
so i notice almost 50 KB speed loss in the cliant computer, and thses speeds may change during time to time
But i think these internet controll softwares canot detect our Internet speeds cus they take all the Asian countries under one section , But if i check the router status i noticed downstreem is 2048KBPS, anyway there are proper internet speed detecting softwares to check the net speed.
But when i downloading some files i download 10MB within 2 or 3 minutes and some files take more than 10 minutes, and i think u cant check the downloading speeds it depends on the time of downloading, downloading server, performance of the modems, routers and finally our ISP's server banwidth.
So i tested my internet speed on the server around 12.30 and it confused me a lot
Communications 288.6 kilobits per second
Storage 35.2 kilobytes per second
1MB file download 29.1 seconds
Last Time 152.1 now 288.6 so it means now i got extra 136.5 kbps than the previous time i checked
1.4 megabits per second
Communications 1.4 megabits per second
Storage 169.1 kilobytes per second
1MB file download 6.1 seconds
Date & time Thursday, February 2, 2:17PM*
Test type IDT4 Free
Connection type Wireless: 802.11
Data size 1024KB
IP address
Provider
  fuzzo said:
we have ADSL at office and at times it is hella slow. you speed also depends on how many other connections there are. if ADSL is new to the area, then you connection willb e very good. the connections are all shared, so if you have more users, dialup will be faster :huh:
OK, this result is a lot better. It shows 409k which is not bad considering this is a 512k connection:
409.6 kilobits per second
Communications 409.6 kilobits per second
Storage 50 kilobytes per second
1MB file download 20.5 seconds
Hey - how about we do a poll to see who gets the best readings for SLT ADSL 512 and 2MBPS connections...
251.9 kilobits per second
Communications 251.9 kilobits per second
Storage 30.7 kilobytes per second
1MB file download 33.3 seconds
  • 2 months later...
  Dilesh said:
hey guys...
Possible causes
* Network error
Solutions
looks like i still have this problem...
Communications 2.3 megabits per second
Storage 278.4 kilobytes per second
1MB file download 3.7 seconds
Subjective rating Great
guys, where r u guys testring these values from? are u guys in SL?
Nope, usa here
Bas******!! :rolleyes::)
915.5 kilobits per second
Communications 915.5 kilobits per second
Storage 111.8 kilobytes per second
1MB file download 9.2 seconds
hey milinda who is ur ISP? me BT
  Overdrive said:
Bas******!! ;)<_<
anyone having a T1 connection?
