fuzzo Posted February 2, 2006 Posted February 2, 2006 link to test Cut n paste your true results ! Here are my results below.. this is ADSL Speed 62.2 kilobits per second Communications 62.2 kilobits per second Storage 7.6 kilobytes per second 1MB file download 2.2 minutes Subjective rating Slow Quote
unknown Posted February 2, 2006 Posted February 2, 2006 is it give true results cable Communications - 651.9 kilobits per second Storage - 79.6 kilobytes per second 1MB file download - 12.9 seconds Subjective rating - Not bad Quote
ruwds Posted February 2, 2006 Posted February 2, 2006 Ethernet Speed 1.5 megabits per second Communications: 1.5 megabits per second Storage: 186.5 kilobytes per second 1MB file download: 5.5 seconds Subjective rating: Great Quote
zeem35 Posted February 2, 2006 Posted February 2, 2006 ADSL 512kbps Speed 61.4 kilobits per second Communications 61.4 kilobits per second Storage 7.5 kilobytes per second 1MB file download 2.3 minutes Subjective rating Slow Info Date & time Thursday, February 2, 3:37AM* Test type IDT4 Free Connection type ADSL Region Asia Data size 1024KB IP address Provider * EST (-0500) SLT ADSL SUCKS Quote
AMG Posted February 2, 2006 Posted February 2, 2006 Hi Guys, I have SLT ADSL 512kb and this is my results. ( I recently got this connection, I've heard the new SLT ADSL is faster than the old connections. don't know whether it's true) 112.4 kilobits per second Communications 112.4 kilobits per second Storage 13.7 kilobytes per second 1MB file download 1.2 minutes Subjective rating Mediocre Explain results Info Date & time Thursday, February 2, 5:44AM* Test type IDT4 Free Connection type ADSL Region Asia Data size 1024KB Regards, Bharath Quote
alfaQ Posted February 2, 2006 Posted February 2, 2006 Here's mine, ADSL Communications 94.9 kilobits per second Storage 11.6 kilobytes per second 1MB file download 1.5 minutes Subjective rating Slow Quote
Az Posted February 2, 2006 Posted February 2, 2006 Speed 103.1 kilobits per second Communications 103.1 kilobits per second Storage 12.6 kilobytes per second 1MB file download 1.4 minutes Subjective rating Mediocre Info Date & time Thursday, February 2, 6:54AM* Test type IDT4 Free Connection type ADSL Region Asia Data size 1024KB IP address 222.165.174.181 Quote
Hanni Posted February 2, 2006 Posted February 2, 2006 115 kilobits per second Communications 115 kilobits per second Storage 14 kilobytes per second 1MB file download 1.2 minutes Subjective rating Mediocre Explain results Info Date & time Thursday, February 2, 7:33AM* Test type IDT4 Free Connection type ADSL Region Asia Data size 1024KB Mediocre. Yup, that describes SLT in a word. LOL link to test Cut n paste your true results ! Here are my results below.. this is ADSL Speed 62.2 kilobits per second Communications 62.2 kilobits per second Storage 7.6 kilobytes per second 1MB file download 2.2 minutes Subjective rating Slow Your results seem a bit lower than they should be? Are you on a shared network? Im curious about ADSL speeds in the various regions in Colombo. I hear that people get different speeds in Kollupitiya, vs Nawala... and so on Quote
Judy Posted February 2, 2006 Posted February 2, 2006 Speed 93.3 kilobits per second Communications 93.3 kilobits per second Storage 11.4 kilobytes per second 1MB file download 1.5 minutes Subjective rating Slow Explain results Info Date & time Thursday, February 2, 9:03AM* Test type IDT4 Free Connection type ADSL Region not listed Data size 1024KB Quote
sharkster Posted February 2, 2006 Posted February 2, 2006 Speed 336.9 kilobits per second Communications 336.9 kilobits per second Storage 41.1 kilobytes per second 1MB file download 24.9 seconds Subjective rating Not bad Explain results Info Date & time Thursday, February 2, 9:47AM* Test type IDT4 Free Connection type ADSL Region Asia Data size 1024KB IP address Provider * EST (-0500) Quote
Pericles Posted February 2, 2006 Posted February 2, 2006 Im curious about ADSL speeds in the various regions in Colombo. I hear that people get different speeds in Kollupitiya, vs Nawala... and so on Its not really the regions. ADSL speed can depend on the distance from the base station. If ur really close to the base station (or exchange), u get the closest to the advertised speed. The more wire from ur house to the base station, the lower the speed. I think it's to do with signal quality. That info should be on the web. Quote
The Don Posted February 2, 2006 Posted February 2, 2006 1.1 megabits per second Communications 1.1 megabits per second Storage 134.7 kilobytes per second 1MB file download 7.6 seconds Subjective rating Good Explain results Info Date & time Thursday, February 2, 11:20AM* Test type IDT4 Free Connection type SDSL Region United Kingdom Data size 1024KB Quote
Watchman Posted February 2, 2006 Posted February 2, 2006 hey guys... i go online ona LankaBELL CDMA... it says the connection speed is 230.4Kbps.... but when i run the test i get this message.. i ran it a couple of time... same outcome.. ======================================== The speed result was too high or too low The speed test will not accept results that are negative or too high for the indicated connection type. This test was not counted. Possible causes * Using "back" from the results page * Using a favorite link or direct URL entry to the results page * Incorrect connection type selected * This test does not support connections above 8mbit/s * Network error Solutions * Start tests from the test start page * Select the correct connection type * Make sure you meet the minimum requirements to use this test ================================== Quote
fuzzo Posted February 2, 2006 Author Posted February 2, 2006 Your results seem a bit lower than they should be? Are you on a shared network? Im curious about ADSL speeds in the various regions in Colombo. I hear that people get different speeds in Kollupitiya, vs Nawala... and so on we have ADSL at office and at times it is hella slow. you speed also depends on how many other connections there are. if ADSL is new to the area, then you connection willb e very good. the connections are all shared, so if you have more users, dialup will be faster Quote
GihanFX Posted February 2, 2006 Posted February 2, 2006 Im using 2Mb ADSL Line Over a Network System ( Wireless + Rj45 Wired ) so i tested all of my computers in the network using the speed tester, but i got various results ( Wireless through a Router --> Server ) ( Network Speed 108MBPS 2.4 GHZ 802.11 ) Communications 152.1 kilobits per second Storage 18.6 kilobytes per second 1MB file download 55.2 seconds Subjective rating Mediocre Then i tested one of my cliant pc ( RJ45 through a Router --> Hub --> Cliant ) ( Network speed 100MBPS ) Communications 100.2 kilobits per second Storage 12.2 kilobytes per second 1MB file download 1.4 minutes Subjective rating Mediocre so i notice almost 50 KB speed loss in the cliant computer, and thses speeds may change during time to time But i think these internet controll softwares canot detect our Internet speeds cus they take all the Asian countries under one section , But if i check the router status i noticed downstreem is 2048KBPS, anyway there are proper internet speed detecting softwares to check the net speed. But when i downloading some files i download 10MB within 2 or 3 minutes and some files take more than 10 minutes, and i think u cant check the downloading speeds it depends on the time of downloading, downloading server, performance of the modems, routers and finally our ISP's server banwidth. Quote
GihanFX Posted February 2, 2006 Posted February 2, 2006 So i tested my internet speed on the server around 12.30 and it confused me a lot Communications 288.6 kilobits per second Storage 35.2 kilobytes per second 1MB file download 29.1 seconds Subjective rating Mediocre Last Time 152.1 now 288.6 so it means now i got extra 136.5 kbps than the previous time i checked Quote
milinda Posted February 2, 2006 Posted February 2, 2006 1.4 megabits per second Communications 1.4 megabits per second Storage 169.1 kilobytes per second 1MB file download 6.1 seconds Subjective rating Good Date & time Thursday, February 2, 2:17PM* Test type IDT4 Free Connection type Wireless: 802.11 Region United Kingdom Data size 1024KB IP address Provider Quote
Hanni Posted February 2, 2006 Posted February 2, 2006 we have ADSL at office and at times it is hella slow. you speed also depends on how many other connections there are. if ADSL is new to the area, then you connection willb e very good. the connections are all shared, so if you have more users, dialup will be faster OK, this result is a lot better. It shows 409k which is not bad considering this is a 512k connection: 409.6 kilobits per second Communications 409.6 kilobits per second Storage 50 kilobytes per second 1MB file download 20.5 seconds Subjective rating Not bad Hey - how about we do a poll to see who gets the best readings for SLT ADSL 512 and 2MBPS connections... Quote
ash Posted February 3, 2006 Posted February 3, 2006 251.9 kilobits per second Communications 251.9 kilobits per second Storage 30.7 kilobytes per second 1MB file download 33.3 seconds Subjective rating Mediocre Quote
Watchman Posted April 22, 2006 Posted April 22, 2006 hey guys... i go online ona LankaBELL CDMA... it says the connection speed is 230.4Kbps.... but when i run the test i get this message.. i ran it a couple of time... same outcome.. ======================================== The speed result was too high or too low The speed test will not accept results that are negative or too high for the indicated connection type. This test was not counted. Possible causes * Using "back" from the results page * Using a favorite link or direct URL entry to the results page * Incorrect connection type selected * This test does not support connections above 8mbit/s * Network error Solutions * Start tests from the test start page * Select the correct connection type * Make sure you meet the minimum requirements to use this test ================================== looks like i still have this problem... Quote
JwesT Posted April 22, 2006 Posted April 22, 2006 Communications 1.7 megabits per second Storage 210.4 kilobytes per second 1MB file download 4.9 seconds Subjective rating Great Quote
Morgoth Posted April 22, 2006 Posted April 22, 2006 Communications 2.3 megabits per second Storage 278.4 kilobytes per second 1MB file download 3.7 seconds Subjective rating Great Quote
Watchman Posted April 22, 2006 Posted April 22, 2006 Communications 2.3 megabits per second Storage 278.4 kilobytes per second 1MB file download 3.7 seconds Subjective rating Great guys, where r u guys testring these values from? are u guys in SL? Quote
Morgoth Posted April 22, 2006 Posted April 22, 2006 guys, where r u guys testring these values from? are u guys in SL? Nope, usa here Quote
Overdrive Posted April 22, 2006 Posted April 22, 2006 Communications 2.3 megabits per second Storage 278.4 kilobytes per second 1MB file download 3.7 seconds Subjective rating Great Bas******!! 915.5 kilobits per second Communications 915.5 kilobits per second Storage 111.8 kilobytes per second 1MB file download 9.2 seconds Subjective rating Good hey milinda who is ur ISP? me BT Bas******!! 915.5 kilobits per second Communications 915.5 kilobits per second Storage 111.8 kilobytes per second 1MB file download 9.2 seconds Subjective rating Good hey milinda who is ur ISP? me BT anyone having a T1 connection? Quote
