HRS Posted June 21, 2016 Share Posted June 21, 2016 Dear All, I have decided to get down a K&N Air filter in order to fix it to my LANCER CS1. K&N (http://www.knfilters.com/) says, their Air Filter is giving 40% more air... Please give your comments on this unit. Thanks, HRS Quote Link to comment Share on other sites More sharing options...
Muditha420 Posted June 21, 2016 Share Posted June 21, 2016 there are a decent amount of info you should read up on before opting for this. some have ruined MAF sensors some with engine issues due to dust filtration. You need to maintain the filter using there oil for the filter etc to keep it working optimum. some removed these due to finer dust getting into the engine. i believe someone in the forum might be able to provide a more in depth info. if you are a regular driver suggest sticking to an OEM filter Quote Link to comment Share on other sites More sharing options...
HRS Posted June 21, 2016 Author Share Posted June 21, 2016 Yes Muditha. I am also having a dough about the filtration. If it's giving 40% more air, their might be more dust crepe into the engine. However, according to the manufacture, they have designed their product to filter more dust than the paper filter. It's worth to read http://www.knfilters.com/filter_facts.htm for their explanation. Quote Link to comment Share on other sites More sharing options...
zebra Posted June 21, 2016 Share Posted June 21, 2016 I used this filter in my EK3. I do not recommenced it for a daily runner as I had to clean the efi, butterfly ... often. The accelerator pedal gets a bit stuck, not smooth. Once the cleaning is done its ok. just my OP Quote Link to comment Share on other sites More sharing options...
Muditha420 Posted June 21, 2016 Share Posted June 21, 2016 i would advice you not to stick with manufacturers sayings and also to check other sites for independent information. I too thought Cone or the normal filter is okay with K&N brand but later heard from users that they encountered issues after this...so i do not want to screw up a good engine. Quote Link to comment Share on other sites More sharing options...
HRS Posted June 22, 2016 Author Share Posted June 22, 2016 yes. totally agreed.. Quote Link to comment Share on other sites More sharing options...
