I think both have been discussed in the forum.
The GP1's a decent ride with a lot of space - if you're a family guy and have stuff to carry you will appreciate it . the car is kind of light . There's a Massive A pillar creating a bit of a blind spot in corners but in time you will get used to it.
If you're buying one try to get the battery checked (esp if YOM around 2010- the GP1 came from 2010-2013)  and if the CVT box has been properly maintained. Since the car's are not that old you'll probably be buying from the first owner so try to see if maintenance records are there
GP2's essentially the same with the only diff being the extra boot-space and slightly higher price tag.
