Hi guys
I need information about engine overhaul process of tercel 2e engine
Mechanics who does this
How much the cost
Engine overhaul or engine replacement if so prices of an engine
Appreciate your comments
1 minute ago, Twin Turbo said:
How have you come to the conclusion that your car engine needs an overhaul?
Yes . Car oil is burning and my mechanic said . It could be oil seals or piston rings or bore . But to verify he said he has to oen and inspect the engine
On 06/04/2017 at 11:32 AM, Twin Turbo said:
You can do a compression test without dismantling the engine.
Can you give a contact of a place which they do compression test . Hard to find a place . I live in moratuwa
