simpleone Posted September 8, 2017 Posted September 8, 2017 Guys, does anyone know a place to buy Lucas Transmission Fix? (in SL) Quote
The Stig Posted September 8, 2017 Posted September 8, 2017 1 hour ago, simpleone said: Guys, does anyone know a place to buy Lucas Transmission Fix? (in SL) You can x 1 r transmission treatment from online retailers Quote
Twin Turbo Posted September 8, 2017 Posted September 8, 2017 Local agent for lucas will not be of help. Try the net, but postage to us may be a prob,.. TT. Quote
simpleone Posted September 8, 2017 Author Posted September 8, 2017 3 hours ago, The Stig said: You can x 1 r transmission treatment from online retailers Thanks Stig. I found it online and very appealing. Only thing is they dont brag about stop slipping as Lucas does. Do you have an experience with this? Quote
simpleone Posted September 8, 2017 Author Posted September 8, 2017 2 hours ago, Twin Turbo said: Local agent for lucas will not be of help. Try the net, but postage to us may be a prob,.. TT. Yeah Postage is outrageous. Does the Lucas agent bring anything else than batteries? Quote
simpleone Posted September 8, 2017 Author Posted September 8, 2017 10 minutes ago, simpleone said: Thanks Stig. I found it online and very appealing. Only thing is they dont brag about stop slipping as Lucas does. Do you have an experience with this? Remembered your thread about transmission slip/jerk when hot. It happens to me when cold now and the car is similar BJ5P. Quote
The Stig Posted September 8, 2017 Posted September 8, 2017 2 hours ago, simpleone said: Thanks Stig. I found it online and very appealing. Only thing is they dont brag about stop slipping as Lucas does. Do you have an experience with this? 1 hour ago, simpleone said: Remembered your thread about transmission slip/jerk when hot. It happens to me when cold now and the car is similar BJ5P. Yes i used x 1r and it actually worked for about 2 weeks. However it was not a permanent fix and i had to go for a gearbox repair. Mine also started slipping even when cold. I guess the average lifetime of the gearbox is around 150k Worth a shot though, only 2k or so. 2 hours ago, simpleone said: Yeah Postage is outrageous. Does the Lucas agent bring anything else than batteries? Mostly battery related stuff like jumper cables, battery water etc. Lucas agents is Browns btw (subsidiary called klevenberg) Quote
simpleone Posted September 8, 2017 Author Posted September 8, 2017 I'll give it a shot and update here. Quote
simpleone Posted September 15, 2017 Author Posted September 15, 2017 Ok. I dumped a bottle of the oil yesterday night and let it settle overnight. Not sure what kind of a sorcery this is, the problem is 85% gone. Well that is more than enough considering the slipping I had previously. Lets see how long this can hold up. Thanks again The Stig. Quote
The Stig Posted September 15, 2017 Posted September 15, 2017 Ok. I dumped a bottle of the oil yesterday night and let it settle overnight. Not sure what kind of a sorcery this is, the problem is 85% gone. Well that is more than enough considering the slipping I had previously. Lets see how long this can hold up. Thanks again The Stig.I think the higher thickness of the transmission fix helps with the slipping. But only time will tell if it's a permanent fix. Quote
simpleone Posted October 16, 2017 Author Posted October 16, 2017 UPDATE: X-1R trick held up for about three weeks. The slipping rate kept increasing a bit by bit until I decided to take it to Nilwala motors. He gave a fix (Free of charge since he had done some work earlier on this) and now its as good as new. Conclusion : Agreeing with The Stig, X-1R works for a limited time. Quote
The Stig Posted October 17, 2017 Posted October 17, 2017 9 hours ago, simpleone said: UPDATE: X-1R trick held up for about three weeks. The slipping rate kept increasing a bit by bit until I decided to take it to Nilwala motors. He gave a fix (Free of charge since he had done some work earlier on this) and now its as good as new. Conclusion : Agreeing with The Stig, X-1R works for a limited time. What exactly was the issue he mentioned ? Quote
simpleone Posted October 19, 2017 Author Posted October 19, 2017 On 10/17/2017 at 8:31 AM, The Stig said: What exactly was the issue he mentioned ? He said the plates had worn out. Quote
