I am really messed with this IAC valve thing. My car has rotery solenoid valve as IAC. RSC coil for closing side and RSO for opening side. ECU provides a PWM to one and inverted to the other. (i.e. If RSO gets PWM with 75% duty cycle, RSC gets its inverted PWM which is 25%. This makes a resultant force to IAC open 50%.)
My data sheet gives the RSC and RSO values attached herewith. Please see picture 1.You can see resultant of IAC is at idling with no AC, is "closed".
But when I check it in my car, the resultant of IAC at idling with no AC is, "opened". Please see picture 2 & 3.
Picture 2 is RSO. Picture 3 is RSC. ( eventhough it should give inverted to each other please disregard it since it's an issue with oscilloscope.i.e. time shift does not shown by oscilloscope.)
1) I checked for vacuume leaks and none found.
2) I also checked these RSC, RSO values at different throttle adjusting screw setting. No change.
3) Checked IAC with values in datasheet and it was OKAY.
4) Also I checked idling speed which is at around 750 rpm.
5) Also I checked rpm when AC switched on which is increased from 750 to around 900.
Pic 1 - first two graphs are RSO and RSC without AC.
Pic 2 - RSC without AC
Pic 3 - RSO without AC
What is the issue in my car? Why can't I get the setup in the datasheet?
Ted
Dear Experts with my all the respect,
4 answers to this question
