sanjeewatr Posted June 29, 2006 Posted June 29, 2006 Honda's engine for the 2006 IRL IndyCar Series is designated the HI6R Series Indy V-8. This engine is a development of the two-time IRL Manufacturers' Championship winning design created in partnership with Ilmor Engineering and introduced at the 2004 Indianapolis 500, when IRL rules reduced engine displacement to 3.0 liters. Engine Type Normally aspirated, fuel-injected, aluminum alloy cylinder block V-8 Displacement 3.0 liters Valve Train Dual overhead camshaft, four valves per cylinder Crankshaft Alloy steel, five main bearing caps Pistons Forged aluminum alloy Connecting Rods Machined alloy steel Engine Management Motorola-Honda Ignition System CDI Lubrication Dry sump Cooling Single water pupm The HI6R will be used by all teams in the 2006 IRL IndyCar Series, with technical support provided by both Honda Performance Development and Ilmor Engineering, Inc. cheers 4 honda racin Quote
xXx Posted June 29, 2006 Posted June 29, 2006 the forum is flooded with honda tec stuff. atleast its better than posting garbage Quote
