Dear AL Friends,
There is a Toyota Hilux that has a 3”x 3” corrosive damage and a developing small crack on the chassis (Chassis location - at the center region straight line down from where the rear door hinges are mounted) does anyone know the technical procedure to get this job done? I figured out that MIG welding a plate would do (instead of ARC welding) but controlling and removing the rust is questionable. must I cut and remove the corroded region or must I just MIG weld the plate over the damaged surface???? Any ideas and advice would be very much of help.  I would be also very grateful if someone would recommend a chassis specialist in Colombo who will be able to get the job done. Thank you very much and wish you all well.
0 answers to this question
There have been no answers to this question yet
