nuwanjjs Posted October 9, 2018 Posted October 9, 2018 i have allion 2007 and it has done around 116,000km. I m second owner according to the service full service needs to be done every 40,000km. What are the things need to be done and how much will be the cost for such service? Quote
Hyaenidae Posted October 9, 2018 Posted October 9, 2018 Cost depends on the workshop... OTOMH 01. Normal Lube service - Engine oil change - Engine oil filter change - Body, underbody, engine bay wash - Vacuum and clean interior - Wheel rotation - Inspect brake system - Inspect Air filter and clean/replace as necessary - Inspect cabin air filter and clean/replace as necessary - Inspect fluid levels (Coolant, 12V Battery, Windscreen washer fluid etc) and refill as necessary - Inspect tire pressure and adjust as necessary 02. Replace ATF / CVTF (Gear oil) 03. Replace brake fluid 04. Engine "Tune-up" - Inspect spark plugs and clean / replace as necessary - Throttle body clean - Ultrasonic fuel injector cleaning 05. Check wheel alignment 06. Inspect and service AC system as necessary 1 Quote
