Buying a Wagon R FZ
Friends
Im planning to buy an used Wagon R FZ. Most likely under 50k mileage. Any tips or advises ? What should i be worried ? What are the problems/repairs i might have in near future?
Thank you
8 answers to this question
1 hour ago, TharinduD said:
Friends
Thank you
Check if it was run with the correct oil 0w-20 5w-30 also cvt oil
Look for badly repaired accidents
Check if the belt adjuster has been replaced
Look at the tyres if they are dunlop enasave as they have sidewall issues
Brake pads will need change,  the isg belt,
Be very particular of the mileage as there is a lot of fraud and these have done heavy miles
Expect the following if so
Hub bearings, front suspension bushes
Shock absorbers, hybrid battery
Also join the wagon r Facebook page, they are very informative.
Thank you for your comment. Is it true that Hybrids are made for just 5 years or is it just a myth? I was told not to buy hybrids that are 3-4 years older.
Also is Wagon R FZ hybrid? i dont see the logo on rear door. If not that means i have to do the emission test right?
The 5 year thing is a myth, mainly coined up because due to the climate here, the hybrid battery packs up in like 5 years,
They are mild hybrids, there is no requirement for an emissions test, more or less an assist, no engine less propulsion
The latest model is badged hybrid but that also is a mild form, however the isg can propel it for a brief time.
This is a myth created  by the car sale mudalalis to peddle their shitty 121's - the actual fact here is that in Sri Lanka's harsh conditions batteries don't last long but that's not always the case. I've said this dozen times before I had a six year old 60,000 Km Honda fit which i sold last year with the battery in perfectly good health.  Currently there is a hybrid-phobia due to some of the popular hybrids developing issues BUT other than the aqua batteries flat-lining the issues with the Hondas - Vezel, GP5, GP1 etc are due to non-battery related issues - namely the Oil leak in GP1 and the DCT issue with the others.
Thank you all for really helpful and informative replies. Can you please tell me what is it like owning a 2014-2015 Wagon R FZ. Maintenance costs, other costs etc? I heard its expensive than normal small car like vitz, picanto, and 100cc range cars
My budget is 2.4M and i thought Wagon R FZ is the ideal solution for my needs. I need a car with good looking, Auto, safe, fuel efficient, and a new car (2010 and up). Are there any good vehicles fit my requirements?
Thanks for helping me out
I do not think this is true, until an issue in the hybrid system comes which is around 150,000km
Running repairs and maintenance is common to all
Then again the price gap is almost 5-7lakhs
You will not be able to get a new one with your budget. Most of the newer Wagon which R available for sale is ex cabs where owners have realized that it is not viable to run a cab with a high lease payment and maintenance.
You can see a JDM Alto which might fit your budget, same mechanical as Wagon R.
