February 25, 20197 yr I'm planning to buy a used Crossover with a factory bodykit installed. However, I want to safely remove the bodykit parts to gain more ground clearance. Any recommendation for a good place?
February 25, 20197 yr If it is really factory and attached with clips or bolts, there maybe holes in the valances and whatnot it is attached to, that maybe a cumbersome idea as you will have to do metalwork to close all the holes and paint it up, most cladding applied locally is with tape, and local kits with rivets, but lately now even local installations go to the extent of drilling holes with a template, so do an inspection prior to attempting anything.
