I have a Suzuki Swift Ignis 2003 model car. in the highway  Roof Rail Front cap was went off now want to buy a plastic cap for it.please suggest me place to buy or suggest solution for this.
4 answers to this question
Try Japan Lanka. If they have a broken rail, you might be able to get a cap off it. If not, you may have to buy the whole thing.
I had the same problem sometime ago. Ended up buying a pair of roof rails. As I recall, it didn't cost much. Around 5000 for the pair I think.
Do i see a crack there in the rail ?  that rail will break away.  You are better off replacing i guess.
Some of my caps are cracked due to UV damage.  Even if I try to remove them to repair, they will break like papadam ?
thank you i ll try there
thank you,yes there is a crack in the rail, i am also thing to replace the rail ,do you know place where i can buy them?
Edited by LASITHA_rox
