April 24, 20197 yr ย Can anyone or you experts can share your idea about 2019 Peugeot 5008. Is it a worthy seven seater to buy? How will it cope up with Sri Lankan context? Will it worth buying or will be a total waste of money?? ย ย Sent from my iPhone using Tapatalk ย
April 24, 20197 yr 4 hours ago, DMPer said: ย Can anyone or you experts can share your idea about 2019 Peugeot 5008. Is it a worthy seven seater to buy? How will it cope up with Sri Lankan context? Will it worth buying or will be a total waste of money?? ย ย Sent from my iPhone using Tapatalk ย Not a pug fan, but Iโve always loved their aestheticsย in this country 2 things are certain, you ll loose money on it when disposing it you ll loose money on it whilst maintaining it. In comparison to popular counterparts. ย Thus the decision is yours, Being a Euro itself outweighs the above.ย
April 24, 20197 yr in the 407,the LCD displays of dashboard,climate control become unreadable when temperatures go above around 25degrees. Is this issue solved in the newer models? Maybe if its imported by agent, would be a hot-climate customized model.
April 25, 20197 yr Author in the 407,the LCD displays of dashboard,climate control become unreadable when temperatures go above around 25degrees. Is this issue solved in the newer models? Maybe if its imported by agent, would be a hot-climate customized model.Hopefully so. [emoji52]Sent from my iPhone using Tapatalk
