3 answers to this question
50 minutes ago, dilan_randika said:
hi,
after i pump 30psi to all 4 tires, when checking after about 1 month, 3 tires become 27. 1 ack tire become 17.
no tire puncture detected after checking in 3 tire shops.
what can be the reason?
Basic car ownership
check the valves, stems
check the tyre bead, pull it off and set the bead again
check the expiry date for the tyre, expired Tyres leak a bit
lastly swap the tyre to another wheel and see if the rim has a leak.
hi,
Basic car ownership
On 5/20/2019 at 5:54 PM, tiv said:
Basic car ownership
at a 3rd place, having said 2 places failed to find, finally found that valve stem was culprit. water buble at 3 seconds interval like, replaced the valve's pin kinda unit....
