fitgp1hmly Posted July 12, 2019 Share Posted July 12, 2019 Recently I bought a toyota vehicle which has the radio/sd/navigation system NSZT w66t. But there's hardly any English in it. Has anyone successfully changed the language? There are videos on how to do that on model w64t. I couldnt find anyone for w66t. 1 Quote Link to comment Share on other sites More sharing options...
kush Posted July 13, 2019 Share Posted July 13, 2019 (edited) Same should work, assume you have the SD card otherwise you might not be able to access settings menu Edited July 13, 2019 by kush Quote Link to comment Share on other sites More sharing options...
alpha17 Posted July 14, 2019 Share Posted July 14, 2019 I have NSCD-W66T(which is a lower version of NSZT-W66T) and I did change the language.Changing the language won’t benefit you, since that only translates the japanese words regarding the navigation department. This option is introduced for the convenience of the foreign tourists who rent Toyotas to drive around japan. Even if you change it, all the music playback areas would still be in Japanese. So best thing is to install Google Translate into your smartphone and then download japanese translator pack. Then you can use the camera translation mode in real time. Select the option and read those japanese words through the camera of your smartphone. That is dead easy. After using it few times, you’d remember all the options. That’s how I squeeze out all the potential from my japanese navigation unit. But remember! If the chip of the system is absent or locked, you won’t be able to do anything. You can find a chip for around 5000-6000 from a car audio place. If the unit is locked from the code (the chip is inside) unlocking would cost you around 2000. Quote Link to comment Share on other sites More sharing options...
kush Posted July 15, 2019 Share Posted July 15, 2019 My nszt-y66t came without SD (hopefully SD will come with the duplicate key) All audio, phone, car information works but i cannot get in to the settings Quote Link to comment Share on other sites More sharing options...
iPrabhath Posted September 28, 2019 Share Posted September 28, 2019 This video is about W66 language change. Probably, W66T has similar settings. Anyway, the language change did not change all menus. Quote Link to comment Share on other sites More sharing options...
iPrabhath Posted November 26, 2019 Share Posted November 26, 2019 https://www.youtube.com/watch?v=F2wEcihBR_E Quote Link to comment Share on other sites More sharing options...
cpaul Posted December 30, 2021 Share Posted December 30, 2021 Radio system NSZT w66t. Has anyone successfully changed the language? Quote Link to comment Share on other sites More sharing options...
alpha17 Posted January 8, 2022 Share Posted January 8, 2022 On 12/30/2021 at 6:34 PM, cpaul said: Radio system NSZT w66t. Has anyone successfully changed the language? Expand I'm afraid to say that you are out of luck. None of these japanese Toyota radios can be fully translated into English. Only models which can be translated are the systems in Mitsubishi vehicles, with models sold internationally, such as Outlander, Eclipse cross. 1 Quote Link to comment Share on other sites More sharing options...
