Conner carter Posted November 13, 2019 Share Posted November 13, 2019 Hi guy's , what does this symbol says? Quote Link to comment Share on other sites More sharing options...
0 AVANTE Posted November 13, 2019 Share Posted November 13, 2019 (edited) Time for oil change. Also, check your oil level/color to be sure. Edited November 13, 2019 by □AVANTE□ Quote Link to comment Share on other sites More sharing options...
0 Conner carter Posted November 13, 2019 Author Share Posted November 13, 2019 On 11/13/2019 at 3:18 PM, □AVANTE□ said: Checked oil level? Maybe oil level is low or something is wrong with the lubrication system but that's highly unlikely on a recent model like this one. Expand thanks for reply . i changed the engine oil at 15000 Km, oil level is fine and there is no any oil leaks too. Quote Link to comment Share on other sites More sharing options...
0 AVANTE Posted November 13, 2019 Share Posted November 13, 2019 On 11/13/2019 at 3:48 PM, Conner carter said: thanks for reply . i changed the engine oil at 15000 Km, oil level is fine and there is no any oil leaks too. Expand I changed my reply, which viscosity did you use? Maybe you didn't use the vehicle for a while and the dash is just going crazy. Our wagonR & Vezel would show ABS, TC, Airbag, lights if we didnt run it for a while. My suggestion is get a scan to diagnose whats going on. Quote Link to comment Share on other sites More sharing options...
0 Conner carter Posted November 16, 2019 Author Share Posted November 16, 2019 On 11/13/2019 at 4:35 PM, □AVANTE□ said: I changed my reply, which viscosity did you use? Maybe you didn't use the vehicle for a while and the dash is just going crazy. Our wagonR & Vezel would show ABS, TC, Airbag, lights if we didnt run it for a while. My suggestion is get a scan to diagnose whats going on. Expand Thanks for all the answer and sorry for late reply. finally solved after changing the Engine Oli. oil color and oil which i use , can anybody suggest me better oil? Quote Link to comment Share on other sites More sharing options...
0 Conner carter Posted November 16, 2019 Author Share Posted November 16, 2019 Thanks for all the answer and sorry for late reply. finally solved after changing the Engine Oli. oil color and oil which i use , can anybody suggest me better oil? Quote Link to comment Share on other sites More sharing options...
0 AVANTE Posted November 16, 2019 Share Posted November 16, 2019 We used havoline for our motorbikes & for our previous cars too. Good for the budget. If you want a better oil, then Mobil1 is the way to go. Quote Link to comment Share on other sites More sharing options...
0 Conner carter Posted November 22, 2019 Author Share Posted November 22, 2019 hi guys i have low oil in transmission what is the oil do i have to fill with CTV or ATF Quote Link to comment Share on other sites More sharing options...
0 AVANTE Posted November 23, 2019 Share Posted November 23, 2019 On 11/22/2019 at 8:26 PM, Conner carter said: hi guys i have low oil in transmission what is the oil do i have to fill with CTV or ATF Expand The every has an Automatic transmission, not CVT. So ATF is what you want. Quote Link to comment Share on other sites More sharing options...
0 Zaheer Khan Posted June 26, 2021 Share Posted June 26, 2021 On 11/13/2019 at 2:46 PM, Conner carter said: Hi guy's , what does this symbol says? Expand My car is prblam for eror Quote Link to comment Share on other sites More sharing options...
Conner carter
9 answers to this question
